96 sebring 2.0 dohc timing belt replacement advice requested
I am replacing the timing belt, idler pulleys and water pump in my 96 Sebring coupe with the 2.0 DOHC engine. Has anyone had firsthand experience doing this job? There does not seem to be any way to remove the engine motor mount which attaches to the block with 3 bolts because there isn't enough room between the timing cover and and fenderwell. I got those 3 bolts completely loosened but can't get them out !
Is there a trick to doing this?
Any help would be appreciated.
Thanks in advance !
Thanks in advance !
Yes, I removed the plastic inner gaurd in order to get at the bolt closest to the firewall. All 3 bolts are loosened, but I still can't get them out.
Have you personally done this job on this engine on this car or a Dodge Avenger?
Thanks.
Thanks.
