96 Sebring Convertible JXI Auto Shutdown Relay Fuse
Hello,
I have a 96 Sebring Convertible JXI 2.5L V6. Once my car has warmed up and I push down full throttle on the gas I blow my auto shutdown relay fuse (ASD). We have replaced the actual relay, the ignition coil inside the distributor, we have checked the computer for codes and nothing comes up, and we have checked the fuel injectors for open wires and we have not found anything. The car runs great. You can barely even tell its running. It starts up perfectly fine, and a complete tune up has been done(cap, rotor, wires, and spark plugs). Any suggestions as to what is wrong with my car?
Thanks for any help you can give me.
UPDATE: We have unplugged the O2 sensor to make sure it wasn't that and it was still shutting down. We then replaced the fuel pump and the car is still shutting down. Taking it to the dealership today to see what they have to say.
Is this while moving or sitting still? ONLY warm engine or any temp? Alternator can also cause your problems.
It sounds like a wire is shorting to ground when the engine is torqued (twisted). Try looking at places where the harness bends around something sharp or a corner. The charge rate of the alternator has no bearing on the matter. The ASD feeds the field coil and there could be a condition that pulls too much current when you ramp up the RPMs. You can unplug the 2 wire connector on it and go for a short drive OR it can be full fielded with the DRB 3.
