96 sebring coupe shimmying
Old 03-24-2010 | 10:34 PM
billyd10's Avatar
Default 96 sebring coupe shimmying
I was trying to get an idea and maybe somone else has had the same problem cause it can be a number of things
Old 03-24-2010 | 11:13 PM
as4k's Avatar
Under what conditions does the car shimmy? Braking, accelleration, turning, etc? Assuming you feel it through the steering wheel?
Yup, could be many things. Help us with a good description and we can help you diagnose it
Old 03-31-2010 | 03:43 AM
97 Sebring Lxi's Avatar
sorry to bump in but my car also gets very light shimmy at speeds around 100 km/h and over, it doesnt get too bad, it also shimmy's when i brake but its just the brake pedal mostly. my car was making loud grinding noises ( i thought it sounded like an old wooden boat creaking) it also feels a bit loose going over rough dirt roads
Old 03-31-2010 | 03:46 AM
thats only when turning, but i basically only heard it going over bumpy turns or when my car was parked and i turned the wheel at high speeds i didnt notice it
Old 03-31-2010 | 11:07 AM
The grinding noises and vibrations during braking are probably due to worn brake pads and warped rotors. A proper brake repair involves replacing these parts and should cure those problems.
"looseness" is a bit vague but could be worn ball joints or worn shocks/struts. Not surprising in a 13 year-old car.
billyd10
04-03-2010 03:54 AM
SOBH35
04-09-2006 04:13 AM
fast2reply
08-21-2005 04:45 AM
FRAM
08-15-2005 06:29 AM
ks LXi
05-13-2005 10:52 PM
