96 Sebring lxi 2.5 No Spark
For about 2 weeks the car would take a few times to start, then one day just stopped starting. Cranks fine, has power to everything, checked fuses, replaced distributor, cap & rotor and asd relay. still no spark at distributor. Tested wire coming into distr and am showing 0 volts coming thru. Looking at replacing the crankshaft sensor next but looking for ideas.
The car has 140k on it
replaced fuel pump and filter about 6 weeks ago
Fuel pump relay tested fine
Ran great until this. Never died or stalled while running.
11: "Intermittent loss of crankshaft and/or camshaft position sensor signals to PCM."
If you have browsed the forum here you'll notice that on that engine, for some reason crankshaft and camshaft sensor failures seem to go hand in hand. Maybe it's time to check the crank sensor.
55: Just means that it has reported all the codes.
WillQRose
10-18-2018 08:18 PM
