97 JXI Transmission issues " stuck in 2nd "
Hi Everyone,
I'm a newbie with transmission issue's [:@]My 97 JXI wich I love by the way and has @155k and still going strong!
Lately,
I will bring it up to operating tempature, and all is well for the first 5 to 10 miles then for some odd reason it shifts in to 2nd gear and wont release out of this gear no matter what you do? I wind up having to drive it back home stuck in second gear, does this mean I amgoing to need a new transmission? or could it be a simpler condition that can be repaired with out the expense of a new trans?
Thanks for any advice you may have
Julia
Lately,
Julia
RE: 97 JXI Transmission issues " stuck in 2nd "
The checkengine light is on, A mechanic at the gas station read a code of the 02 sensor malfunctioning, but said he may be reading it incorrectlyand it could also mean something else?[X(]
But to me, actually this little light is kinda confusing[:'(]I thought that a check engine light wassuppose to bea easy way to diagnoise a problem witout the guess work.
Anyhow I will reluctantly[&o] take it to the transmission shop and have it checked out, unless their mightbe anything else you guys can think of that will cause this situation and can be repaired cheaper ?
Other than submitting it to the dreaded transmission shop
Thanks for any more advice!
Update: 06/23/08
Since last thread transmission has been rebuilt at a cost of $1400.00 rebuilt by santa ana transmission O.C Ca. ( best deal I could find ) running and shifting fine now.but now having ECU/computer problems 158k battery light coming on, not charging, intermittant and getting worse? Apparently I have been diagnoised as needing a new ecu $500 after already replacing battery and alternator $200, Does this happen often with this model? looks to be a factory thing to get spend more of your money? as with the trans also[:@]after reveiwing all posts pertaining to?
Thanks as always for any expert advise
MrNoizyToyz
10-02-2012 10:26 PM
DJBowens
04-26-2011 06:44 PM
