97 sebring 2.5 that run some times only in idle
Old 09-08-2008 | 11:11 AM
jaydub54's Avatar
Default 97 sebring 2.5 that run some times only in idle
first ive check almost every thing yet u say check the circuit. i have three wire on tps and volts were 5.60 on ohm meter what should it read? one more thing after i erase all codes how is it that one or two codes stay before i crank po122 or p0123
Old 09-11-2008 | 07:32 PM
Default RE: 97 sebring 2.5 that run some times only in idle
The voltagefrom the TPS should be between 0.16 and 4.5 volts. You may need to both replace the sensor AND check for the source of high voltage.
It's best to just "reply" rather than starting a new thread for an old problem.
NoFurula
03-31-2015 08:01 AM
Alex255
02-26-2015 07:53 PM
Alex255
02-24-2015 12:42 AM
XtremeCuztoms
12-19-2006 03:22 PM
03-23-2006 06:00 AM
