98 jxi no crank
Old 02-18-2012 | 10:50 PM
hoss's Avatar
hi there yes removed battery from car and took it to parts store autozone
Old 02-19-2012 | 06:24 AM
what what were the readings when they tested it?
Old 02-19-2012 | 10:22 AM
hoss's Avatar
i think it was 14.6 and 10.9 i know he assured me that it was good the battery is 1 1/2 years old
Old 02-19-2012 | 05:27 PM
and the CCA? if they load tested it that will show u what the CCA was at the time which I am suspecting it is low like in the 300 range.
U can have a battery 12volts and 0 cca and the car will not turn over.
  #15
Old 02-19-2012 | 06:56 PM
hoss's Avatar
should i have it tested again for cca's i going to try the battery from ford diesel which i know has big cca's to see will it start again many thanks for all your help so far
  #16
Old 02-19-2012 | 07:40 PM
hoss's Avatar
next test pulled wifes expedition next to it disconnected battery cables on jxi connected jumper cables to pod ang neg on jxi still nothing not sure if this is to be expected just letting you know tried ir both with expo turned off and running still nothing
  #17
Old 02-20-2012 | 12:19 AM
replace the battery how many days have u wasted trying to look past the obvious
  #18
Old 02-20-2012 | 10:12 AM
I'm not so sure the battery is the problem if it won't start after jumping from the truck.
Maybe it's time to get busy with that volt-ohmmeter and check for continuity and signal starting at the starter and working backwards toward the key.
That .16 Amp you got doesn't necessarily mean anything. When you disconnect the battery there's a little surge when it's first reconnected.
PowerAuthority
10-13-2009 06:49 AM
sassycc
06-30-2009 03:51 PM
sumncguy
05-19-2007 02:28 PM
BigBlocksnHardrock
04-07-2007 01:19 PM
Tripp1117
Cirrus & Breeze
01-28-2007 02:37 PM
