98 Sebring key stuck in ignition
Old 02-15-2007 | 02:18 PM
Justme1969's Avatar
Default 98 Sebring key stuck in ignition
Good morning...I am hoping someone who may have had this problem can give me an insight on what is going on with my Sebring. I have a 98 Sebring and the key is stuck in the ignition. I can start the car and drive the car fine but when I go to turn the car off the key will not come out of the ignition. Any ideas? Thanks in advance for any help.
Old 02-15-2007 | 04:07 PM
Default RE: 98 Sebring key stuck in ignition
make sure the shifter is all the way in the park force it forward. Either the adjusment is out on the cable, or shifter damage or shift lock sol is bad haft to check
Old 02-24-2007 | 12:47 PM
rob's Avatar
rob
In the manual on my 2006 it specifically mentions this as some type of "feature" malfuntion and says the dealership will help you with it.
Old 03-06-2007 | 02:29 AM
ace's Avatar
ace
I am not certain but did you check to see if the recall for the shift interlock was done to your car? I think it may apply call the dealer and have the service dept run the vin to find out of any open recalls on your car. It may be the shifter is not fully in place to remove the key.
Old 06-15-2007 | 06:22 PM
mjr20fan's Avatar
Ok I have a 2005 Chrysler Seabring and yesterday my key got stuck in the ignition. Now I can't get it out at all. Has it been confirmed that there has been a recall on something that would cause that problem? Any help would be appreciated...thanks so much!
Old 06-15-2007 | 08:53 PM
your key stuck in the ign would not be a safety issue thus no recall would come of it.
tbird2340
02-19-2020 05:41 AM
scottshaw
01-12-2014 11:01 PM
jent84
09-22-2012 10:55 AM
pete3000
07-19-2011 09:38 AM
woody79
06-11-2010 10:59 AM
