99 2.5 water pump inlet tube
Old 02-08-2015 | 05:54 PM
RichyRich001's Avatar
Default 99 2.5 water pump inlet tube
99 2.5 water pump inlet tube is leaking. can I take just the drivers side items off to change it? (Including the intake of course) Or do I have to remove the water pump as well?
Old 02-09-2015 | 04:11 PM
No one knows the answer to this question? Somebody here has changed a inlet tube before. HELP!
Old 02-08-2018 | 09:27 PM
Chris Fenning's Avatar
Doing this repair right now.
In short, yes you can leave the water pump in. You have to take the Thermostat/Coolant filler housing. Just remember, if you are leaking out of the water pipe inlet on one side, chances are its bad on the ither side and may require the kind of attention that requires the water pump and timing assembly...
Ny repair started off as a simple timinfg belt replacement, and here I am.
Pacifica830
07-10-2017 01:47 PM
dmbeale
15
11-24-2010 07:26 PM
captain catfish
10-02-2010 05:32 PM
chief
K-Cars
07-19-2008 01:54 PM
chief
07-19-2008 01:45 PM
