99 Sebring Convertable directionals not working
Old 04-25-2010 | 06:41 PM
99SebringNH's Avatar
Default 99 Sebring Convertable directionals not working
Ok so heres the deal I just bought a 99 Sebring convertable for the summer and the directionals don't work.I checked the fuse and it is ok and all the lights work when turned but nothing from either directional.Any and all help will be greatly appreciated.
thanks
Bob
Old 04-26-2010 | 03:38 PM
Check the bulbs again. The bulbs for the turn signals have two filaments. Just because the bulb lights when you turn on the running lights doesn't mean that the turn signal filament is working.
If it's not that, then the problem may be in the switch or the wiring or a ground.
Old 05-05-2010 | 07:29 PM
arnehoff's Avatar
Besides bulbs, you may have a turn signal flasher out. Many people are also changing to LED bulbs also. LED bulbs are not compatible with the stock flasher because there is not enough current draw. If that is the case, change the flasher to an LED compatible one.
andrew61
11-08-2012 11:05 AM
dpbrowne
01-24-2011 05:10 PM
newbe
11-18-2007 11:19 AM
PIMPINPHIL
10-17-2007 06:29 AM
ace
11-18-2005 01:13 AM
