Alot of heat under dash
Old 08-18-2011 | 09:58 PM
jen2swt's Avatar
Default Alot of heat under dash
Just recently the Sebring has ALOT of heat coming from under the dash. The car is not overheating, but man is that heat brutal on my legs while driving. I can also feel heat in the middle console arm rest...
Any idea what it could be?
Old 08-19-2011 | 09:20 AM
1) What model Sebring is it?
2) Do you have automatic temperature control?
3) Have you set the heater controls properly?
Old 08-20-2011 | 11:16 PM
helo735's Avatar
sounds like the cat is getting hot. SES light on?
Old 08-21-2011 | 07:29 AM
jen2swt's Avatar
2001 Sebring...just a standard..
Heater Controls? There is no automatic temp control.
Old 08-21-2011 | 07:30 AM
jen2swt's Avatar
Cat? As in Catalac Converter? SES light? There are no lights on.
Old 08-21-2011 | 03:23 PM
"Have you set the heater controls properly?"
That was a question. "There is no automatic temperature control" does not answer the question.
Old 08-21-2011 | 09:01 PM
helo735's Avatar
In all reality, to show that I'm not a complete troll...
Does it seem like there is a fan blowing the heat on your legs? What happens when you adjust the heater controls? Have you changed the HVAC settings?
It sounds (at least to me) like the HVAC is blowing hot air on your legs through the floor registers. If everything is set correctly, then something within the HVAC could be messed up.
Old 08-21-2011 | 09:02 PM
helo735's Avatar
Since I apparently can't edit posts, try also to turn your A/C on, and see how that affects it.
Old 08-22-2011 | 09:37 PM
Kubikus's Avatar
just had similar problem - very hot engine compartment and engine temperature guage show middle of scale. Check EGR valve - seal it off if it helps change EGR valve.
Old 08-22-2011 | 09:46 PM
helo735's Avatar
That wouldn't explain how the heat is getting through to the passenger compartment though.
I'm still leaning toward something being fuxored with the HVAC system, with it being stuck on heat or something.
Op, if you have the setting on the heater controls, try swapping it to Recirc instead of fresh air. See if that helps at all.
