ANOTHER 2001 sebring swap to 2004 QUESTION?
ok i have looked and looked and can not find a sure answer.. i have a 2001 sebring with bad heads/water pump. i also have a 2004 sebring smashed in the rear.. runs shifts great 110k miles. can i swap entire cradle assembly with the pcm from 2004 into the 2001 and it run correctly without swapping flexplate or cam gear? sure i will have to swap minor stuff but hope i wouldnt have to separate engine trans assembly? or tear into timing? Thanks for any help!!
tear into timing the wire connectors are not compatale with 2 different computers even transfering over the whole PCM tcm and harness they wont connect into the rest of the car. Stuff like your Cluster wont work inside
lep0407
06-06-2013 03:22 PM
andbudzi
02-20-2008 05:07 PM
