ANTIFREEZE LEAK HELP!!!
Old 06-28-2008 | 11:24 PM
romoakatruebeast's Avatar
Default ANTIFREEZE LEAK HELP!!!
97 chrysler sebring ...need help !!!put new gasket and sealant on thermostat housing and still leaks out somewhere under neath the housing i dont know if its coming from there or somewhere else underneath of it ..it would be greatly appreciated if any help would be provided...
thanks
Old 07-02-2008 | 12:29 PM
johno's Avatar
Default RE: ANTIFREEZE LEAK HELP!!!
If you have a 2.5Mitsubishiengine then it's pretty likelyleakingfrom a Metal tube that runs inside the V part of the v-6 engine, between the front of the engine (being the water pump/timing belt) .and the back of the engine(being the thermostat).There is an o ringabout 1.5 inchsize of on both ends of the tube that keep the collant from leaking into the V part of the engine.
Well the o-ring is likely leaking behind the thermostat. and leaks down between the tranny & the engine. and ends up on the ground.
If you find another way to fix the problem PLZreplay to this posting.
Mine leaks a little and i thought about using the stop leak goo but that stuff clogs your rad and heater core,,,& my heater core has issues giving heat affter -10 degrees F,,,i am cold
As far as i know you would need to remove the timing belt water pump and that is how the tube and Both o rings come out.
I have no clue about the 2.7 engine that is Chryslers engine. not sure if it has a tube or not.
Old 08-08-2008 | 11:41 AM
thorze's Avatar
[:'(]I had the Same problem and what I found was the two freezeplugs under the bellhousing had rotted out. I had my mechanic fix it for around $500 and I haven't had a leak since. Try not to take it to a dealer, they will insist the whole engine needs to come out, which it doesn't!!!
RÖENTGEEP
08-08-2012 12:27 PM
Jerry32
07-13-2011 09:43 AM
RayDog26
11-06-2008 03:33 PM
gbeach
04-21-2008 11:19 PM
ronryben
07-13-2006 04:48 PM
