ASD relay
Old 12-17-2014 | 04:06 PM
dna9656's Avatar
Default ASD relay
I have a 2007 Sebring with the 3.5 V-6. I need to perform a compression test, the book says to pull the ASD relay, I have found both the LARGE combination fuse/relay electrical box and the small box with 4 relays under the hood on driver's side. EXACTLY which relay is the ASD relay please.
Old 12-17-2014 | 08:22 PM
it will say ASD relay
Old 12-18-2014 | 03:20 AM
dna9656's Avatar
Well what and where does it say ASD? I looked in the gang of 4 relays and there was no verbiage just as there was no verbiage in the fuse/relay panel.
Old 12-18-2014 | 10:22 AM
I fount it are you not looking in your owners manual for the descriptions and locations?
use the page 246
Old 12-18-2014 | 03:51 PM
dna9656's Avatar
use the page 246
Owner's manual shows ASD relay feeds 1,2 and 3. It does not identify any relays.in the TIPM (fuse box).
Old 12-19-2014 | 02:16 PM
download the owners manual from chrysler.com page 246 is the layout of the fuse box
Old 12-20-2014 | 05:53 AM
dna9656's Avatar
The Adobie reader "page" 246 is tire info, when doing a "control key and "f" for "find" seach of "ASD" adobie's reader page 319 a pic of the fuse box appeares showing the information I have already posted, it shows FUSED FEEDS to the ASD relay, there is feeds 1, 2 and 3 as I have already stated, please don't re-post info to me (or others) we have already shown on the forum, info that is of no help. I have lots of info that's of no help, I have the owner's manual as I stated already, I gave the page number and the ASD fuse sites feeds 1, 2, and 3, these are NOT relays, they are FUSES. The book says PULL THE RELAY. I have the Chrysler service manual, I have the Haynes manual, that is all that is available on the open market and still the info isn't there I need info that says 'go to the (what ever box) and pull the fuse 3 from the left when looking at the fuse in such and such a way" The fuses on my car are NOT identified, or I am looking in the wrong box. Please direct me to the proper location (box or strut tower, or driver's side fire wall. I don't need info I already have that isn't helping, that I have posted that I already have that isn't helping or help from people that can't read and understand a post on a forum for information that doesn't refer me to said useless information.
Old 12-20-2014 | 11:16 AM
They used to put a legend on the inside of the cover of the fuse box identifying everything in there. Don't they do that anymore?
Old 12-21-2014 | 02:04 PM
dna9656's Avatar
There are location numbers only, I believe my number is 30. I called the dealer's parts counter to find out where it's located. Some of the locations are defined, some are defined better than others.
Old 03-28-2018 | 12:53 PM
Mhblackie50's Avatar
Default My 2011Chrylser 200 will not start
I am at my end. I truly don't know going on with my 2011 Chrysler 200. I had arrived home from work. After two to three hours being in the house, I was preparing to leave. I turned the key and the car started to cranking (normal cranking), but wouldn't start. I didn't have no warning light and still there is no warning light. I here the fuel pump running and I charged the battery. I haven't check the fuses, which I am planning to do today. Does anyone can help me with this problem. I did a google search and I did noticed several people who experience this problem with their Chrysler. I don't understand if several Chrysler owner experience, why there is no solution. Some says that they experience a lot of problem with the 2.4L motor. They can be many causes to my problem. It will be difficult to find a solution, since I didn't have any Check Engine Light.
