Blower motor switch power question
Old 07-06-2013 | 10:06 PM
ebby69k's Avatar
Default Blower motor switch power question
My blower motor switch does not work in any position. I did a quick check at the connectors at the switch with the ignition on and find no power at any of the wires. The 30 amp fuse appears to be good. There should be power at somke of the wires I would think. I think I saw somewhere there is a fuse/relay inder the hood?
Old 07-07-2013 | 08:30 AM
Could be a fuse, could be the resistor block. There's a legend in your owners manual for the fuse panels of the car. You have provided no details about your car so this is just general, but many Sebrings have a fuse box under the hood and another behind a panel at the left end of the instrument panel.
There should also be a legend on the underside of the cover(s) of the fuse box(es).
The resistor block is usually found in the heater box behind the glove compartment. Search the forum here for discussions on how and why to replace that part.
Old 07-07-2013 | 10:14 AM
need to know year make and model as well
Old 07-07-2013 | 10:54 AM
ebby69k's Avatar
2004 Sebring 4 dr Sedan
Old 07-07-2013 | 10:58 AM
ebby69k's Avatar
I just thought it was odd there was no power at any of the wires at the fan switch connector with the ignition on.
Old 07-07-2013 | 12:35 PM
power goes to the blower motor first the resistor is part theat controls the ground check for power at the blower motor connector 2 wires green and black
Old 07-07-2013 | 04:37 PM
ebby69k's Avatar
Yes I see that now thta I found a wiring drawing. I jumped the blower and it did not work. I decided to go ahead and pull it and a lot of water came out. Where did it come from and what should I do or look for? Thanks
Old 07-07-2013 | 10:00 PM
The air comes into the system through the cowl in front of the windshield. Rain comes in there, too. You also get water from condensation when the A/C is running. Water in there should drain out through a tube that goes through the firewall. Look for a rubber hose that comes through the metal firewall and just ends. Try squeezing and/or massaging it a bit to allow the crap in it to fall out. You get dead bugs and dirt in there to the point that it just gets plugged up. Sometimes parking under certain kinds of trees aggravates the problem with little leaves and stuff that falls in there.
Old 07-08-2013 | 08:31 AM
ebby69k's Avatar
Thanks for all the help everyone. Found the hose and tons of water flowed out of it. Pretty sure the water damaged the motor. It does not want to spin.
Old 07-09-2013 | 09:31 AM
ebby69k's Avatar
I installed a new blower. Problem fixed. Thanks all....
darkcild101
13
07-30-2015 09:08 AM
seqx34
11-20-2014 03:26 PM
Woolvett
01-13-2012 07:48 PM
gooch
05-28-2011 04:39 PM
LT102
03-01-2008 12:34 PM
