Brake Light Problem
Both filaments in both taillights are intact. What fuse(s) should I check? If the deck lid stop light works but not the other two, should I eliminate the brake pedal switch as a possible cause? Sure hope it's not a wiring problem! Thanks, DC!
If the center high mounted stop light (known as the CHMSL) works, then forget the fuse and switch as all the stop lights go through the same fuse and switch. (Fuse 11 under the hood).
The stop lights are fed by a white and tan wire. Check that for voltage when the brake pedal is depressed. If you have voltage there, then the only other likely thing is a bad ground. Check the black wire for ground.
monsterdub
05-05-2024 12:10 PM
4everrunning
06-04-2019 12:30 PM
blackoutken
9
12-29-2012 02:26 AM
