broken tire screw/bolt on a Sebring 2008
Old 06-26-2014 | 10:15 AM
usdollar's Avatar
Default broken tire screw/bolt on a Sebring 2008
Hello
If anyone knows please tell me what is the exact name of a tire screw (the 5 screws that holds the rim) in order to look on the net to buy it.
And as well, please tell me how could i change it... if it's not too complicated or at least a video with something similar...
The screw was stuck in the nut and broke when i tried to unscrew it.
PS. Is it safe enough to go around on 4 screws only?(front wheel)
Thanks!!
Old 06-26-2014 | 04:34 PM
It's called a "stud". With the right tool, you can easily press it out of the hub. You might be able to get the tool on loan from a local auto parts store, but if not, it's an easy repair for a shop. You might be able to pound it out with a hammer and a punch but that's a very bad idea and will probably wind up damaging the bearing.
Driving around on four studs is not a good idea. The manufacturer put five of them in there for a reason. They don't spend extra money on the cars they build for no reason.
Old 06-27-2014 | 06:28 AM
usdollar's Avatar
Thank you very much !
TimmyTim
11-01-2013 07:43 PM
mkweaver
06-20-2011 07:21 AM
peabodyn
03-09-2011 02:50 PM
KYBarrister
10-13-2008 06:52 PM
KTMguy
01-03-2007 08:51 PM
