Charging system issues on '98 Coupe
Old 01-12-2010 | 11:38 PM
bds0688's Avatar
Default Charging system issues on '98 Coupe
My car has been exhibiting some odd behavior, that I can only assume is the result of a bad ground or wire.
Once in awhile while driving, it'll act as if the battery is no longer part of the equation.
The brake pedal, turn signals, high beams, all will make the radio and blower motor cut out momentarily when switched. Lights flicker as if just off the alternator.
When the car is parked and turned off, the key going to "ACC" results in a completely dead car. Battery is new, reads 12.5 resting.
Now, say I add a jumper to the battery terminals, car starts just fine.
Car has actually been starting fine for the past few days, and running normally. However, due to it being winter, I am holding off on driving it until I have a better idea of what it could be, before I break one or more expensive components. Thanks for any help.
Old 01-13-2010 | 11:51 AM
Check both ends of both battery cables for corrosion. A thin film of corrosion can act as an insulator. Sometimes it will be able to carry a small current but not a large one, sometimes a large current can break through but not a small one.
Take the connections apart, clean them up until you see shiny metal, put them back together and coat with vaseline.
Zoomer55
09-23-2019 05:27 PM
Kman1971
06-17-2014 01:04 PM
blkdout_tsi
01-25-2014 11:16 AM
Johnja
11-04-2007 05:53 PM
drwalker88
Other
07-07-2005 04:40 AM
