CHECK ENGINE LIGHT
Old 06-04-2007 | 10:40 PM
DAN's Avatar
DAN
Default CHECK ENGINE LIGHT
I tried to get my 99 chrysler sebring smogged. It didn't pass because of my check engine light. The error codes i received were P0174 system too lean(bank 2), P0155 o2 sensor heater fault(bank 2 sensor 1) and P0151 o2 sensor low voltae(bank 2 sensor 1) I changed the upstream oxygen sensor on the manifold, but 5 days later the check engine light came back on. Any advice on where to go next. bank 2 and sensor 1 is referrence to what?
Old 06-05-2007 | 05:01 PM
Default RE: CHECK ENGINE LIGHT
what is the new code same one or different?
oh btw what engine and hard top or convertable
Old 06-06-2007 | 09:57 PM
DAN's Avatar
DAN
I didn't give enough information, sorry about that.Hard top, v6 2.5 liter engine
Old 06-07-2007 | 12:30 AM
what is the new check engine light code?
Old 06-09-2007 | 11:12 AM
DAN's Avatar
DAN
P0174 SYSTEM TOO LEAN IS STILL PRESENT AFTER CHANGING THE OXYGEN SENSOR
Old 06-09-2007 | 11:31 AM
that means the computer it taking away more then 30% of fuel for longer then the time required. With that info u can have several different tings that will tell the computer to do that. This will be for skilled people so if u dont want to get into this I understand here are a few of the things that can make it go that direction. o2,coolant temp sensor, high fuel pressure,
ENGINE VACUUM - must be at least 13 inches in neutral
ENGINE VALVE TIMING - must be within specifications
ENGINE COMPRESSION - must be within specifications
ENGINE EXHAUST SYSTEM - must be free of any restrictions
ENGINE PCV SYSTEM - must flow freely
ENGINE DRIVE SPROCKETS - must be properly positioned
TORQUE CONVERTER STALL SPEED - must be within specifications
POWER BRAKE BOOSTER - no internal vacuum leaks
FUEL - must be free of contamination
FUEL INJECTOR - plugged or restricted injector; control wire not connected to
correct injector
qbasicer
09-25-2012 03:58 PM
RobinVA
01-05-2010 11:18 PM
cacarrollsr
Cirrus & Breeze
11-11-2006 11:47 PM
teresadogg
11-02-2005 04:21 PM
ChryslerNamedTrixie
10-20-2005 04:06 PM
