Coolant is Boiling . smoke coming out .
Old 08-26-2012 | 01:46 PM
manan's Avatar
Default Coolant is Boiling . smoke coming out .
when I drive for 15min or so . My engine temp gauge goes up to nearly H . and i can see the smoke coming out from coolant side. and when i stop the car i can hear the boiling sound. I have just replace the readiator cap and top up coolant still i am having a problem. Plz help .. here is the pic where i can see the smoke coming out everytime.
here is Link :Flickr: Manan46's Photostream
Thanks You
Old 08-26-2012 | 04:06 PM
Thundercraft's Avatar
smoke or steam?
Broken head gasket?
Old 08-26-2012 | 04:30 PM
manan's Avatar
Steam . .. does it have to do anything with Thermostat housing/
Old 08-26-2012 | 09:50 PM
My apologies. I did not look at the pictures the first time.
Pressure test the system when it is cold.... I'm guessing that your thermostat housing is cracked.
Old 08-26-2012 | 11:52 PM
its call a water outlet housing
Old 08-27-2012 | 11:48 AM
Thanks for the proper terminology
Old 06-04-2018 | 04:20 PM
gpatel's Avatar
Default Water outlet housing, fan did not come on. 2006 Sebring 2.7 touring. Coolant
let
hi, i have found a hole in my water outlet housing and will replace it. But my qestion is why did the fan not come on when temp indicator went into RED zone and steam pouring out and antifreeze all over block.
There does not appear to be any antifreeze in oil. So why did the fan not come on? The 2 fan relays look visually ok. I will switch 2 of the relays next to each other to see what happens.
What is the third fan relay for?
i have never seen the fan come on. When on highway the temp needle is alwsys a quater up and reads normal.
if head gasket leaking, will it leak into oil? How can i tell if head gasket issue?
i had to top up antifreeze about 2 litres 2 weeks ago for first time because check engine light came on, then now houseing blew a hole. I cannot turn the bleed valve on the housing to bleed air, its that tight. I am afriad i will break housing if i force it. I tried to open the bleed valve on old unit i just took put, but could not turn it. I am wondering if the air traped inside caused the steam to boil inside the high point of housing causing it to fail. Some say do not bleed via valve and air will escape from resovoir tank, but i'm nolonger a beliver in that. I just cant see how to bleed air out of this car? Any advice
Old 06-08-2018 | 09:37 PM
To answers that question if you have the 2.7 the coolant temp is at the top of that housing so if u have low coolant whats up there to show the temp? hot air the sensor was not showing the correct temp to make the fan come no.
Old 08-05-2019 | 03:22 PM
boatmoter's Avatar
sounds like a thermostat issue
Old 08-07-2019 | 08:55 PM
2004SebringSedan2.4L's Avatar
you could bypass the thermostat and have the fan running continuously as a short term fix. Also your picture is not working.
