Coolant leak
Old 06-27-2010 | 11:09 AM
burgmo3's Avatar
Default Coolant leak
My sisters 2004 sebring has a leak with some dried up foam looking crap coming from a part on top of the engine. I don't know what it's called but it has a big hose connected to it attached to the radiator. If anyone knows what I'm talking about could you tell me what the part is called and how hard it is to replace. I can get pictures if needed.
Old 06-28-2010 | 10:29 AM
Which engine does the car have? V-6 or four cylinder?
Old 06-28-2010 | 08:14 PM
burgmo3's Avatar
2.7 v6
Old 06-29-2010 | 11:50 AM
That thing is called the coolant outlet manifold. There's lots of discussion about it on the forum.
See here for example: https://www.chryslerforum.com/forum/...ht=gear+wrench
It's a bit tricky to replace it but with the correct tools you can do it without removing the upper intake manifold.
The part is available from the dealer but with some diligent detective work you can find it for much less elsewhere, including on the web.
Old 06-29-2010 | 05:21 PM
burgmo3's Avatar
Hey thanks for your help. My sister is taking it to the dealer tomorrow and I didn't want them giving her a line of bs since she's a girl.
Old 06-29-2010 | 08:25 PM
ArchtopBill's Avatar
My local dealer wanted nearly $500 to replace this part. I was able to do it myself one evening after work using a part from AutoZone for less than $75.
Old 06-29-2010 | 11:11 PM
burgmo3's Avatar
I don't know enough about cars or dodges to fix it myself my mazda is so easy to repair a baby could do it.
Old 06-30-2010 | 08:23 AM
3 hose clamps, four bolts (okay, one of them is a little tough to get to) and one screw is all it takes. It is probably easier to do than replacing the rear bank of sparkplugs.
billbon8
14
03-22-2022 09:18 PM
neh218
64
11-28-2011 04:54 PM
Spellbreaker
03-11-2010 05:27 PM
funjon1
03-31-2009 08:48 PM
92lebaron
12-30-2007 09:57 PM
