Damper fork touble
Old 11-10-2011 | 06:46 PM
fakeplay's Avatar
Default Damper fork touble
Hi I'm changing over my stuts and the damper fork is giving me trouble.
The bolt to the lower control arm will not budge. I backed off the nut to the end of the bolt and wacked it with a hammer but it did not move. Any suggestions ? ps I did not remove the stablizer but does that matter ? the bolt should have moved should'nt it ? Thanks
Old 11-11-2011 | 02:26 PM
What kind of car are we talking about here? I assume it's a Sebring, but what year and model? Coupe? Sedan/convertible?
Old 11-12-2011 | 10:59 AM
fakeplay's Avatar
Default damper fork
Hi, It's a 98 sebring conv. jx The bottom bolt to the damper for (clevis bracket) The bolt seem to be frozen in. I hit it pretty hard a couple of time but it did not budge. Would heat work you think ? Thanks
Old 11-13-2011 | 06:18 PM
Be careful with the heat. There's a bushing there you don't want to ruin if you can help it. I believe that bolt has a serrated shoulder to prevent it from turning. Those serrations have a lot of surface area that has probably gotten corroded over the past 13 years. You might want to try some PB Blaster and ATF in there, then get a bigger hammer. You'll probably need to replace the bolt after all that beating on it.
Old 11-14-2011 | 10:11 AM
fakeplay's Avatar
Default Damper fork
I know there's no bushing. I have two spare clevis bracket s And they are just flanged bolts. Yup, maybe a bigger hammer (wich I have) Thanks
kgillespie
07-27-2021 09:34 AM
sharkygb3
04-03-2014 02:57 PM
harrysaimbhi
23
05-06-2010 03:42 AM
harrysaimbhi
03-29-2010 07:52 AM
jakefree
01-27-2007 08:36 AM
