dash lights tac
Old 09-25-2005 | 04:05 PM
jojo56's Avatar
Default dash lights tac
My dash lights go off and on and the tac doesn't work when this happens this has happened a couple of time sometimes when I start it up again they come on
Old 09-26-2005 | 05:43 PM
ViperGTS's Avatar
Default RE: dash lights tac
A little more info: It's a 97 sebring convertible jxi
-Matt-
Old 12-07-2005 | 01:21 AM
sulup's Avatar
Hi,I have a 97 JX conv. 6cyl.My tach and odometer worked sometimes.I found out with these cars there are 3 tiny blue resistors on the circuit board behind the dash cluster(thats all the gauges in your dashboard)have to be resoldred.In order to do this you have to take your dash cluster out of the car.Those resistors get hot and melt the solder connections.They have to be resoldered.I went on Yahoo and found instructions on how to fix it.Type in chrysler dash clusters on Yahoo and you should find it.By the way I fixed mine and it is working like new.Good luck.
Old 12-07-2005 | 01:25 PM
JXI101's Avatar
yeah, he's right, but you need to use a high temp solder, and probably a 40 watt iron.. I know, it's hefty, but they'll never come off ever again.
Old 12-08-2005 | 04:53 AM
ChryslerNamedTrixie's Avatar
This might sound dumb but I'll give it a shot in the dark any how... at Auto Zone, we carry a product called "Bulb Grease"... and it's pretty self explaning... just put the grease on the conection end, and the receiving end of the bulb, and conector, and it might help... but, like I said.. this was just a shot in the dark...
Old 12-12-2005 | 07:18 PM
BLACK JACK's Avatar
I HAVE HAD THE SAME TROUBLE, THANKS FOR THE TIP..
cuda2000
16
01-14-2014 04:42 AM
Johnbush1
02-22-2008 05:00 AM
GSKI
13
09-11-2007 10:33 AM
andypandy22a
03-06-2006 11:43 PM
Family Guy
03-03-2006 05:27 PM
