downstream o2 sensor
I have a 2002 chrysler sebring with the 2.7 engine in it. I keep getting the code downstream o2 sensor is neither positive or negative. I changed both oxygen sensors ( the upstream and downstream) and did a vacuum test on the cat which was o.k. Should I still go ahead and change the cat or try something else?
Thank you I changed the front downstream sensor. I will change the rear bank sensor and let you know.
