drivers mirror replacement
Old 07-23-2007 | 06:48 PM
amfmnsam's Avatar
Default drivers mirror replacement
My wife has a 2005 convertible limited that she clipped the plastic cover of the driver's side mirror, then I backed into with a chair to break the glass. How tough is it to replace, I see no fasteners?
Old 07-23-2007 | 08:55 PM
Default RE: drivers mirror replacement
want to replace the whole mirror or just the glass?
Old 07-24-2007 | 08:23 AM
amfmnsam's Avatar
Whole deal, would be the preferred way to go, if managable. I read your help to another fellow and it involved removing the interior door panel with a special tool. If anything special is required, please direct me to a source.
Thans for your help.
Old 07-24-2007 | 09:36 AM
REMOVAL [ol][*]Remove side view mirror cover (Side View Mirror Cover).[*]Remove the door trim panel (Refer to 23 - BODY/DOOR - FRONT/TRIM PANEL - REMOVAL) .[*]Disconnect power window mirror motor wire connector, if so equipped.[*]Disengage wire harness grommet from mirror flag, if so equipped.[*]Disconnect manual mirror adjuster from side mirror cover, if so equipped.[*]Remove nuts attaching side view mirror to mirror flag (Side View Mirror).[*]Remove side view mirror from vehicle.[/ol]
REMOVAL Door panel
[ol][*]Roll door glass down.[*]Disengage two clips attaching speaker grille to door trim panel. They are at the front of the grille, one near the top, and the other one at the bottom.[*]Remove three large washer-headed screws surrounding the speaker (Lower Door Trim Panel Removal).[*]Remove access cover at front of door trim panel. Remove by prying at its rear edge (Mirror Bezel and Door Trim Access Cover).[*]Remove red courtesy reflector from lower tail or door. Disengage by prying at screwdriver notch at bottom of reflector.[*]Remove flag trim panel from door by prying off at two attachment clips points (Mirror Bezel and Door Trim Access Cover).[*]Remove seven screws attaching door trim panel to door: (Lower Door Trim Panel Removal) and (Mirror Bezel and Door Trim Access Cover).[*]One screw is located at lower rear screw pocket.[*]Three screws located along the bottom of door.[*]One screw located inside handle opening.[*]One screw located at the upper front.[*]One screw in the pull cup. [/ol][*]Disengage two hidden clips attaching at the rear of the trim panel, by prying off at two attachment clip points.[*]Lift trim panel upward and away from door, disengage trim panel from upper retainer channel.[*]Disengage clip attaching latch linkage to back door handle.[*]Disconnect electrical connectors as necessary, including lower foot light, If equipped.[*]Remove door trim panel from door. [/ol]
Old 07-24-2007 | 10:35 AM
amfmnsam's Avatar
Thanks dude,
Step one, remove side view mirror cover, seems kind of simplified. Does it just clip on? Where are the points I should focus pressure?
What is the best tool, flat blade screwdriver?
Old 07-24-2007 | 12:09 PM
trim stick or trim removal tool a screw driver might bend the plastic
Old 07-24-2007 | 12:42 PM
amfmnsam's Avatar
Where can I get a trim stick?
Thanks for your time and efforts.
Old 07-24-2007 | 12:55 PM
auto parts store
96LHSinfinityspeaker
03-11-2010 05:23 PM
Davidstingray
11-02-2007 03:33 PM
p_cruicks
03-25-2007 04:23 PM
02-27-2006 10:54 AM
bourquepa
12-05-2005 11:32 AM
