Front subframe interchange ??
I have an 06 Sebring Touring 4 door, the front right wheel was slammed into a curb at some point in the past by the previous owner. The front right wheel is pushed back and the frame itself is tweaked.
It drives and tracks fine but I am wanting to fix it by replacing the whole front subframe. Long story short, mine is an 06 2.7, Touring 4 door, which models will interchange? I have a shot at 3 different 04 4 door parts cars but I believe they are all 4 cylinders, any differences in the subframes? I will still be using my 2.7......
The Dodge Stratus sedan should also work. Do NOT even consider a coupe. It's a totally different car. The subframe from a convertible might also work but you might need to drill some holes.
Go down to the dealership and try asking the parts counter guy to look up the part numbers for what you need and what you are considering. If the part number is the same, you're golden. Bring a box of donuts to share.
MoParrMan
10-30-2013 03:03 PM
