Glove Box 12 Volt power
Old 04-07-2012 | 05:35 PM
Arthur Aghakhabian's Avatar
Default Glove Box 12 Volt power
Hi, I have a 2005 Sebring Coupe Base. The power coming from the 12 volt accessory socket in the glove box is continuous, which means that if the key is out of the ignition it will still continue to charge my gps (my GPS is hooked up to it for charging). I was wondering if it is possible to make it where it only turns on when you put the key in and turn it to the ACC setting, making it non-continuous? Thanks, Regards, Arthur.
Old 04-07-2012 | 05:36 PM
Im sorry, its not the glove box, it's the compartment where your arm can rest.
Old 04-07-2012 | 06:41 PM
TNtech's Avatar
In either of your fuse boxes, do you see a fuse that has a 3rd terminal that is vacant ?
Old 04-08-2012 | 02:25 AM
Yes I think there is a third one vacant right next to the two 15A fuses that each control the 2 accessory sockets. Here are some pictures for further clarification.
JMKendrick
10-04-2012 03:23 AM
TrenchRT
07-23-2012 02:39 PM
ghmpin
02-07-2010 09:23 PM
ma_pacifica
04-30-2009 06:41 PM
town1985
08-20-2008 08:27 PM
