Heating problems and winter is here soon..
Folks, we've had our 2003 2.7 sebring for just over a year now and it's been pretty good as a second car. However, we've had a heating problem since we bought it and and struggled through last winter but don't want to do the same this year.
In a nutshell, the car doesn't give hot air, just mildly warm and not enough for a cold winter. It also takes quite some time to warm up but get's to the right temp eventually and sits there fine, which suggests to me anyway that the thermostat is ok.
I've checked the pipes running into the car and they both seem to be warm.
Any ideas? Heater core? Thermostat?
I'd like to change the thermostat anyway so is that a DIY job or not?
Changing the thermostat on a 2.7 is not as easy as it should be. Basically, it involves removing the alternator. The thermostat housing is not on top of the engine but rather is underneath and a bugger to get to. If you think you may be up to the task, get either a shop manual or a Haynes manual and study it to decide whether you feel it's a DIY project for you.
Low heat output could be a problem with low antifreeze levels, or possibly with the blend door in the heater not operating properly. That in turn could be a problem with the blend door motor or the control head or the wiring, or even the body computer since they decided to let the computer get involved in the heater operation.
Folks,
Some progress, albeit small. I replaced the heater control unit today and there's defo some improvement, maybe significant!
However, after I did a calibration, I got the code AC 48 flashing on the speedometer. I've done a google search and that code means a/c control switch not grounded or something but I have no idea at all what that means?
Advice?
Advice?
Folks,
Advice?
Advice?
I have the same code.
Hinners
10-26-2013 06:43 PM
