Help changing heater/AC speed resistor 2001 Convertible ltd
Old 05-03-2010 | 07:36 PM
mrnoonan's Avatar
Default Help changing heater/AC speed resistor 2001 Convertible ltd
I have a Sebring 2001 Convertible Limited.
I've read other posts about the problems with the fan speed control (speeds 1-3). I purchased the resistor.
I can't figure out how to get at the under dash location which I understand is on the passenger side.
I've tried to lower the glove box byt depressing the rear sides but there are what appear to be rollers that don't compress/depress and are in the way.
The appear the be no screws or latches to pull off the bottom of the glove box or the horizontal foot kick trim panel. There is one bolt and nut recessed into the foot panel below the glove box. I didn't want to mess around with something that I'll regret later.
I'm mechanical and can do this but I need a clue where to start.
Thanks, Mike
Old 05-03-2010 | 11:34 PM
the lower cover on the pass side comes out 2 push pins and it will come out
Old 05-04-2010 | 04:44 PM
mrnoonan's Avatar
Thx Chrysler Tech for the quick response.
I can't find the pins you mention but looking at the bottom of the glove box cover I see 3 hinges. The middle one looks to have no access but the end hinges have holes.
Is the right place to look?
if so, do I poke a small screw drive tip in a hole or slide something horizontally, or what?
thx for any help.
Old 05-04-2010 | 11:58 PM
the big black cover under the dash right below the glove box
goggs
43
11-07-2014 07:53 AM
asconana
11-21-2010 03:48 PM
ChristieRose
10-27-2009 11:23 PM
weinerschizel
07-14-2008 02:01 PM
LeeJay
08-25-2007 01:48 PM
