Help with codes 1193,505,455,442!
Hello,
I'm new here and I need help with some codes. I have a Sebring 2002. I know what the codesmean but I don't know how to fix them. The last 2 codes have to do with the evap system and I'll start by changing the gas cap to see if that works. The first 2 codes I don't have a clue. I want to fix the simple things first and work my way through.
Please help!
Please help!
RE: Help with codes 1193,505,455,442!
the 1193 is inlet air temp high is the sensro pluged in ot not?? its on the filter hose that goes into the throtle body assembly.
the 505 is AIC ckt have u checked to see if it works or not?what tools and test equptment do u have?
I also have a code problem (2001 Sebring LXi Convertible). The code is P0601 - Internal Control Module Memory Check Sum Error.The Service Engine icon has been on for quite some time and the Airbag icon comes and goes. It didn't bother me until I went for my yearly inspection sticker. The state says I have 30 days to correct it. Please help. Thanx. Butch
no help can be given U need a new engine computer no way around it. IF u are under 8 years or 80k miles u can get a new one for free from a dealer if not u will be charged for the part and labor for insatll and program. DO u live near Atlanta I can get the computer for 10% over cost and I will charge much less then a dealer for insatll and program.
