I have a mess going on!
Old 07-13-2014 | 03:13 PM
sea-one's Avatar
Went to AZ and had to order them, 4 days to get them. I ordered the downstream NGK's and they were listed as LEFT and RIGHT. Assuming standing in front of the engine. also these are LOCATED on the Converters not ''downstream'' per-se' but its obvious.
NOW what do i do with the code 300! also when i clear codes with my little $100 tool THE engine light comes on gain on restart, Never goes off....hasn't for months .
Im very mechanically inclined and can NOT figure this car out! i Have to get it straight but all i can do now is do online research,
I guess i need to take it to the stealership to scan the PCM... Will a Reflash help?
i once disconnected some plugs on the box under the master cylinder above the transmission for another repair and i forgot to plug them back and tried to start it! Dumbass on my part but we all are at one time or another..How would that effect anything..
Please guys i need some help. im wearing the hood cable out
Mike in Dallas
Old 07-13-2014 | 03:32 PM
sea-one's Avatar
Ok Codes today are
p300
p1129
p152
p038
Also when i took the so called in correct Bosch o2 sensors the one on the firewall side was Light with a cleaner grey on the tip.
Old 07-13-2014 | 03:41 PM
sea-one's Avatar
Heres the ansewr to my Left and Right answer,.. i was wrong
https://encrypted-tbn1.gstatic.com/i..._XuB5KjeQ0JvNQ
Old 07-13-2014 | 06:51 PM
sea-one's Avatar
Default Why are the spark plugs like this?
Just went out to take it apart and re-look everything,
and pulled the plugs (NGK Iridium) and looK!
Bank 1 plug. (#1 cyl side)
Bank 2 Front side of the car
2 totally different burns on each side, The 3 cylinders on the firewall side are all light and the 3 cylinders on the front are all rusty brown color.
  #15
Old 07-15-2014 | 11:52 PM
sea-one's Avatar
I replaced both downstream o2 with oem and new plugs and cleared the codes - started the car and 2 seconds the engine light back on with 4 codes
p038 p052 and
p038 p052 yes, just like that, back to back
  #16
Old 07-16-2014 | 11:32 PM
sea-one's Avatar
Found a connector by the pcm half connected, Fixed!
  #17
Old 07-21-2014 | 11:10 PM
Thundercraft's Avatar
Ouch. That was a frustrating issue.
Thanks for posting the eventual fix... you probably saved some others from banging their heads against the wall.
First rule of trouble shooting.... is it plugged in.
pacman069
11-16-2019 11:58 AM
neex
02-14-2015 09:39 PM
9cirrus8
Cirrus & Breeze
07-07-2011 11:08 PM
Dougburgy
10-09-2009 02:06 PM
08-02-2005 12:35 AM
