Idle Issues with '02 sebring 2.7L
Old 12-30-2006 | 04:09 PM
spoolerr's Avatar
Default Idle Issues with '02 sebring 2.7L
My 02 chrysler sebring recently started leaking coolant from the water outlet, the seam was leaking which i hear is a common problem. I got a new water outlet from the dealership, removed the upper intake, replaced the water outlet housing and gaskets, replaced the upper intake gaskets and re-connected all vacuum lines and sensors. When i started the car it stumbled a bit, but after a few seconds ran normally. Now i have an intermittetent idle issue, very similar to the one described here http://www.faqs.org/qa/qa-21559.html.
When first started, the engine would rev up to about 2700 rpm, then settle at around 2200. This problem went away for about a month after a few days, but now it is back again and it has the exact same symptoms as before. The car always runs faster then it should even when fully warmed up.
Has anyone had any similar problems, or better yet a solution? I have checked for vacuum leaks, removed the intake a couple of times to inspect for cracks or damage, replaced the gaskets twice, double checked all sensors, lines etc. This problems is very frustrating and the only code i get is a P1294 (target idle not reached)
thanks in advance,
brandon
Old 12-30-2006 | 06:06 PM
Default RE: Idle Issues with '02 sebring 2.7L
here ya go right from chryslers diag manual. I think u have a vac leak if it was not there br u did some work then u made the prob. Just my experence in dealing with things that have been tinkered with =)
70 roadrunner
12-03-2014 08:48 AM
icekillah
07-07-2012 01:15 PM
Cschaefer0716
12-02-2011 12:21 AM
fatboy803
10-10-2010 02:21 PM
macfarlane300
02-02-2009 10:00 AM
