Intermittent Dash Light issue
Old 04-30-2011 | 10:13 PM
hyprshart's Avatar
Default Intermittent Dash Light issue
Well hi, i am new to your forum and am in need of your wisdom/guidance
My sister owns an 07 sebring (limited with the 3.5 if that helps)
She has recently had an intermittent issue with her dash lights not coming on when the headlight switch is toggled, the other lights in the car like the radio, and HVAC controls do so it is not the switch, but the next day it is fine, a week later it happens again. i am a tech for a chevy dealer so i can do any work on the car but i dont want to start tearing it apart and not know what im looking for.
Dean
Old 04-30-2011 | 10:57 PM
TNtech's Avatar
Is it JUST the cluster lights that are doing it?
Old 05-01-2011 | 10:49 AM
hyprshart's Avatar
yes it is only the cluster backlight, the gauges, warning lights, and info center continue to function normally.
Old 05-09-2011 | 10:29 AM
Jeepy's Avatar
Default link
Here's a link to what may be your issue.
Hope it helps
CSCC Home Page • View topic - How To: 1G Repair intermittent tach/odometer circuit board
CSCC Home Page • How to repair your intermittent dash (tachometer/odometer)
I hope Im allowed to do this for u.
This is a pictorial of how to fix a burnt out solder joint on the back of the instrument panel.
Old 07-09-2011 | 06:08 PM
hyprshart's Avatar
well i know its been a while but my sister has just been putting up with it not working once a week, but this past week it has not worked once. so i removed it (a very simple one to remove by the way) and looked at how the cluster is lit, it uses a ribbon connector that i didnt feel was tight enough so i tightened it up by layering some paper behind it and recalmped it down and tada she works, hopefully it will last but now i know what it is atleast
Old 08-09-2013 | 06:53 PM
Ruslan's Avatar
Default Chrysler Sebring instrument cluster lighting not working
I had the same issue with my car and the problem was a bad inverter. I found a video on youtube done by vehix411.com. This might be helpfull. Here is the video.
StratLou
05-05-2015 01:07 PM
dannyboyindc
03-05-2015 06:51 AM
Nosmo
11-08-2013 01:19 PM
fbongo
07-17-2013 03:46 PM
Chris Freelund
11-28-2011 06:43 PM
