irratic idle??
Old 05-23-2013 | 12:47 PM
larry9972003's Avatar
Thumbs down irratic idle??
My car starts and runs fine in the morning. after warms up the idle drops intermittently fromn about 700 to 500 rpm and the oil light comes on? if I rev the gas increasing the rpm the engine light goes off. any ideas??? I also just changed the engine in this vehicle with a used 80000 miles one because mine was 220000 and leaking ect... had problem before I vhanged engine too???
Old 05-23-2013 | 11:43 PM
Engine idle speed is controlled by the PCM which controls it via the idle air control motor. The oil light is a known problem with 2.7L engine (don't know what engine you have). Replacing the oil light switch is a cheap way to deal with the problem and might solve it. If not, you may have real oil pressure problems.
Old 06-24-2013 | 01:43 PM
Default irratic idle cont.
mine is a 2.5L 1996 model.
Old 06-24-2013 | 04:04 PM
70 roadrunner
12-03-2014 08:48 AM
Greasey monkey
08-15-2011 10:33 AM
macfarlane300
02-02-2009 10:00 AM
OTWOLIMITED
01-31-2007 12:43 AM
fubutx
Cirrus & Breeze
02-03-2006 10:23 PM
