Keyless Entry
Old 10-10-2008 | 06:35 PM
chasers's Avatar
Default Keyless Entry
When i bought my car it was built with a keyless entry but some way and some how the dealership didnt have it so does anyone know where i can find a reasonably priced remote and how to program it?
Old 10-10-2008 | 09:34 PM
xfire04's Avatar
Default RE: Keyless Entry
try ebay if you have the owners manual it will tell how to program the remote
Old 10-10-2008 | 09:41 PM
xfire04's Avatar
if you dont have the owners try chrysler .com an upload your manual
Old 10-11-2008 | 12:12 AM
If you wind up with more than one remote, program all of them at the same time. If you program one and then get another one later, again, program all of them at the same time (within 30 seconds). If you program only one of them, it will un-program the other. This is stated in the owners manual but it's easy to overlook.
Old 10-11-2008 | 08:42 AM
bandaide's Avatar
Check your manual first, but I think with no remotes available, you're going to wind up at a dealer to do the actual programming. But if you provide the remote(s) it should not be too pricey. If you had one remote, you could use the manual steps to match in additional units. The same with the Sentry keys.
Old 10-11-2008 | 08:00 PM
chasers's Avatar
Okay, Thanks, ill check it out.
Old 10-11-2008 | 09:54 PM
Here's the instructions from my 2001 Sebring owners manual:
[ol][*]With the vehicle in Park, turn the ignition switch to the ON/RUN position.[*]Using a currently programmed transmitter, press the Unlock button on the transmitter. Continue to hold the Unlock button, wait at least 4 but no longer than 10 seconds, then press and hold the Panic button for at least one second. Release both buttons simultaneously. You will hear a chime signal that you can proceed with programming the new transmitter.[*]Press and release the Lock and Unlock buttons simultaneously, followed by a press and release of ANY button on each new transmitter to be programmed as well as the original transmitter. You will hear a chime when a transmitter has been successfully programmed. You will have 30 seconds to finish programming all new transmitters. A chime will sound when the 30 seconds is over or the ignition switch is turned to the LOCK position.[/ol]
Now it's pretty clear that you must have one working remote to get into the programming mode. All is not lost if you don't have one. The dealer can program a transmitter without having one that works. Using the DRBIII scan tool, the technician enters BODY, BODY COMPUTER, MISCELLANEOUS then PROGRAM RKE, then follows the instructions on the screen.
I have included the latter so that when you go to the dealer and ask them to program your remote, you will be able to tell them what to do when you get the usual blank stare from the write-up guy. The bad part is that they will probably charge you $85 for the service.
Of course you can always run out and buy your own DRBIII tool. I've seen them on eBay for $6,000.
Old 10-27-2008 | 04:45 PM
chasers's Avatar
Thanks a lot! My only problem is i don't have an existing remote so i guess ill have to take it to the dealership to get it programmed. They want $51 to program it. :/
Oh well, thanks again for the info. u have provided.
Casper_1984
05-09-2008 12:36 AM
97LXIgirl
02-24-2008 11:04 PM
96SebringJxi
10-28-2007 12:26 PM
Sebring Sedan 01
08-30-2006 01:37 AM
94_concorde
07-19-2006 04:38 AM
