Locating Fuel Pump on 99 Sebring LX Coupe
Old 08-01-2009 | 11:25 PM
Cellguru's Avatar
Default Locating Fuel Pump on 99 Sebring LX Coupe
So our mechanic claims the fuel pump should be under the seat, but all there is under there is the fuel gauge sending unit!
Where have they hidden the pump, anyone know?
Old 08-02-2009 | 02:37 AM
Cellguru's Avatar
Default Found it, but still won't stay running!
So there are 2 accesses under the back seat, one obvious in the center, and one on the passenger side, kind of under the carpet and no so obvious.
Put in the new pump, car started up, idled for 5 minutes and died.
What to check next?
Old 08-02-2009 | 02:54 PM
Codes?
Old 08-03-2009 | 08:52 AM
Cellguru's Avatar
Default No Codes
Not even a check engine light, just dies and/or will not start.
Old 08-03-2009 | 01:01 PM
You need to take a systematic approach to finding out what is wrong: Don't assume that the new fuel pump is working. Check for fuel, spark. If either is missing, you will need to figure out why.
Not all codes light the check engine light. Scan for codes if you can.
Old 08-04-2009 | 08:42 AM
Cellguru's Avatar
Default Systematic Approach
Thanks DCotter, I am trying, this isn’t even my car.
Here is my systematic approach, over 10 days or so!
  • Car dies
  • Distress call
  • Tow car home
  • Try Starting fluid test
  • Car sputters and tries to start
  • Conclusion Fuel Related
  • Contact mechanic for price
  • He says it’s under seat, no sweat
  • Order fuel pump (~65)
  • Open up center access
  • Discover gauge sender, no pump
  • Waste 36 hours trying to locate the pump
  • Buy Haynes manual @ AutoZone $25
  • Chapter 4 figure 5.3 plainly shows the cleverly concealed second access under carpet and foil.
  • Replace pump
  • Start and idle for 5 minutes
  • Back out of shop for test drive.
  • Car Dies
  • Malted Beverages
  • Contemplate Cash for Clunkers program
  • Scrap CFC, owner too broke.
  • Borrow Bro in-laws tow dolly
  • Tow to Pro
  • Sleep like a baby!
Thanks All
Old 08-04-2009 | 08:36 PM
Amazing how those malted beverages clarify the whole thing. Let us know how it all shakes out.
Old 08-04-2009 | 09:22 PM
Cellguru's Avatar
Default On the road again !
So the pro found the Crankcase Positioning Sensor to be bogus, back on the road 3 hours after we dropped it off.
No idea of the damages, it was one of those friend of a friend yada yada!
Thanks again
Old 08-05-2009 | 05:19 PM
That would be the Crankshaft Position Sensor. If that was bad, there would have been no spark, and the engine computer would have lit the check engine light, and generated an error code.
Anyway, back on the road is good.
Darth Menace
02-19-2016 10:16 PM
Arthur Aghakhabian
08-15-2012 09:19 PM
36rascal
08-02-2011 01:02 PM
a_kraker99
06-27-2011 11:32 PM
Sierrasan
10-20-2008 10:47 PM
