Making an 04 Sebring top manual
Old 10-17-2019 | 10:44 AM
Kebring04's Avatar
Default Making an 04 Sebring top manual
I want to make my 04 Sebring automatic lift top into a manual lift. Can I do this just by disconnecting the hydraulic arms? Or will I need to do more?
Old 10-17-2019 | 11:11 AM
You'll have to get out of the car to pull it up.
Disconnecting the hydraulic cylinders should do it. Make sure you disconnect at the correct end.
Old 10-17-2019 | 11:45 AM
Kebring04's Avatar
Which end is the correct end?
Old 10-17-2019 | 02:12 PM
Disconnect the end that attaches to the convertible top frame. Leave the end that's anchored to the body of the car in place. Someday you or a subsequent owner may want to get it working again. Be sure the cylinder is out of the way of the frame as it goes up and down. Secure it in place so it won't rattle or go where it shouldn't.
Old 10-17-2019 | 02:37 PM
Kebring04's Avatar
Awesome thanks for the advice. On my car the cylinders only attached to the frame and had a locking plate that kept them in place so I removed the whole assembly.
Connie Hamilton
08-19-2019 07:14 PM
rickster
07-27-2017 02:42 AM
bjxhwd
12-11-2011 07:33 PM
racergirl21
08-27-2010 07:39 PM
mikeyboy
04-09-2008 11:41 AM
