No power to the Cigarette/Power outlet
Old 09-14-2008 | 02:54 PM
meandmunch's Avatar
Default No power to the Cigarette/Power outlet
Hello,
My power outlet assembly fell apart inside the dash after using and MP3 player for a couple of years. It just slowly untwisted apart. I reassembled it and discovered I had no power to it. I check and recheck the fuses all were good. I went to my Chrysler dealer then ran through the same loops, check the assembly and checked the fuses. No power. They pretty much gave up. The only remaining option/theory is something is wrong with the wiring (which sounds impossible)? How can that even be? Does anyone have any theories, alternative solution, something I'm missing? Can a fuse go bad and you can't actually see the damage? I just think it's silly I can't get it to work.
Thanks,
Tom
Old 09-14-2008 | 06:45 PM
Default RE: No power to the Cigarette/Power outlet
its a blue 20 amp under the hood square
tkbelisle
08-17-2012 06:13 AM
keely111
06-08-2011 05:45 PM
AZJOHN
06-30-2010 01:46 PM
dski76
08-03-2008 05:01 PM
chary
10-17-2005 06:57 PM
