no spark
no spark
Hi all, I hope someone can help. we have a 2000 sebring with
no spark, car stoped running after it threw # 4 spark plug.
I changed distributor, crankshaft sensor, asd relay, all
fuses good, fuel pump working, timing belt good and all
timing marks in line with #1 tdc. no codes with odb scanner.
distributor cap intact with new spark plug wires and plugs. hope some can lead me in some direction with this car Thanks Chuck
Hi, yes my son called me about 3 miles from home, we drove it with no problems. we put in a new plug and then it would not start. the plug did not look too bad and the threads look good and hold tight. also battery is full charged
It means that part of the computer is working. IF it turns out that you have to replace the computer, search on line for a source. I was able to replace mine with a service that lists on eBay. You give them your VIN and odometer reading and they will ship you a properly reprogrammed computer for about $200. You send them your old one after swapping it out.
Dealer wants over a grand for a new PCM.
I'm not saying that your computer is bad, only that it could be, based on all the other things you have apparently ruled out.
By the way, is there any issue with this car having a history of cheap bank financing? I have heard of some finance companies installing a device to remotely disable the vehicle if the payments are not up to date. Imagine the chaos those things cause years later.
WillQRose
10-18-2018 08:18 PM
