O2 Sensors
RE: O2 Sensors
As I understand it, there should be one O2 sensor for each exhaust manifold. And those are the ones I think you've found. The "values" that these generate are compared to the "value" generated by another O2 sensor near the outlet of the catalytic converter to determine if the exhaust has been cleaned up as well as the richness or leanness of the exhaust gasses.
Unless you've lifted the car off the ground, I doubt you'll be able to reach it, let alone see it because the ones I've seen on other vehicles have been mounted between the exhaust pipe and the floor pan. You'd have to have really, really long arms and fingers.
latreto
01-21-2014 04:03 AM
winterstormfront
05-16-2007 09:07 PM
winterstormfront
05-16-2007 09:07 PM
