Oil in spark plug galleries
Had my 01 Sebring 2.4 DOHC for a little over a year now and decided to change spark plugs and wires. While swapping out the two center plugs, (cylinders 2 and 3), there was about an inch or inch and a half of oil sitting in the spark plug galleries. Any ideas as to how it got there? I'm thinking it is either the old plugs weren't seated tightly, or the top valve cover is somehow leaking into these plug holes. Is this a common occurance and/or am I into costly repair by a technician?
Thank you! So to replace the tube seals, I have to replace the whole valve cover gasket as a kit. Is this a big job with specialized tools, or can a knowledable backyard mechanic do it easily? I work for an aftermarket parts store and can do most of my own repair work. I've never taken the top off a DOHC before, but it doesn't look to complicated at first look. Anything I should watchout for? Or would you recommend a qualified tech do this job?
emhomes
01-19-2014 05:42 AM
IB Editor
11-23-2011 02:42 PM
strange everytime i plug the plug into the sensor on my coolant water outlet my radiator fan stops..
musicfreak2195
02-12-2009 03:17 PM
