Other cars with same engine 6G73
I am trying to do a little research and found the following that may be good information if you are looking for parts.
Mitsubishi 6G73
The 6G73 displaced 2.5 L (2497 cc or 152 cid).
It was a 24-valve DOHC engine with a smaller bore
than the 3.0 liter version of the same block. Bore
and stroke were 3.29 x 2.99 (83.5 x 76.0); it was a
60-degree V6 and weighed around 342 lb (155 kg).
The engine had low-profile cast aluminum heads which
helped it to fit into small engine bays, while pent-roof
combustion chambers increased efficiency and made room for
four valves per cylinder, arranged in a cross-flow pattern
with a "tumble" intake port for both strong breathing and
low emissions. Spark plugs were centered in the combustion c
hambers. The intake valves were 1.30 inches (33 mm) in diameter
while exhaust valves were 1.14 inches (29 mm). A toothed timing
belt was used. [1]
Applications:
* 1995–2000 Chrysler Sebring/Dodge Avenger
* 1995–2000 Chrysler Cirrus/Dodge Stratus
* 1990–2002 Mitsubishi Diamante
* 1992–1996 Mitsubishi Galant
* 1995–1998 Dodge Avenger
Hey Chrysler Tech / bandaide ... any comments on this one ... is it accurate ?
Mitsubishi 6G73
belt was used. [1]
Applications:
AxerJk
06-29-2011 10:42 PM
