overheating problem
Old 11-03-2011 | 02:43 PM
deefabo27's Avatar
Default overheating problem
I have a 2005 Chrysler Sebring Sedan Limited. When I turn on my heat, my car overheats. I was told that I needed a thermostat, but I dont know. Can anyone tell me what to do as far as getting this problem fixed? Or tell me how to fix it myself to save money?
Old 11-03-2011 | 03:25 PM
Laimon's Avatar
what engine do you have ? mileage ? are you losing coolant ?
Old 11-03-2011 | 04:24 PM
a broken or bad thermostat will not cause the car to over heat when u turn on the heat.
Old 11-05-2011 | 05:42 PM
deefabo27's Avatar
Its a 2.7L DOHC 24 Valve. It has roughly 107,400 miles. And when it overheats it loses coolant. Do I need a thermostat?
Old 11-05-2011 | 05:57 PM
There are many possible causes of overheating. Leaves and debris clogging the radiator, collapsed radiator hose, bad thermostat, coolant leak, inoperative fan(s), plugged radiator core, blown head gasket, wrong or weak or old coolant, bad radiator cap, etc, etc.
Check what you can. If you can't figure it out by yourself, get someone who knows what he's doing to look the system over. There are tests that can be run (coolant specific gravity, pressure tests) that can rule out some things. Nobody can do that over the internet.
moparnewby
08-23-2010 08:15 PM
ptqueen79
12-30-2008 03:56 PM
baseballchris05
05-07-2007 08:38 PM
mykej27
03-12-2007 10:22 PM
Morparth
06-19-2006 11:04 PM
