P1139...and others
P1139...and others
I just installed a new engine my car and now it won't start. The car has a 2.7l dohc, just give you a little description of the car. Everytime I go to turn the ignition, a fuse blows. I've checked the codes and came up with P1139. I've did some research and saw a suggestion where it said to remove the fuel pump relay and see if it blows then. If it doesn't then to change the fuel pump. Does that sound about right or what?
You can see what things are controlled by certain fuses by looking in your owners manual and by looking at the underside of the cover to the fuse box. You might get lucky and find what you need at this site:
Car Alarm, Car Stereo, Mobile Video, and Cruise Control Info for Installers
If not, the service manual has a very large section on wiring diagrams. Are you saying you did an engine swap and don't know where to find this stuff?
MrSaratoga
11-24-2013 07:10 PM
SanDiegoPac
09-22-2009 02:43 AM
