P1400 Mnifold Pressure sensor!!!
Old 03-24-2008 | 02:17 PM
01 SEBRING 3.0's Avatar
Default P1400 Mnifold Pressure sensor!!!
Hello everyone, new here, looking for answers! I have a 2001 sebring 3.0, the car runs fine, however the ses light just came on. The code is a p1400, manifold pressure differential sensor. I checked for vacuum leaks, fixed a couple, replaced the front(easy) valve cover gasket...it was leaking. I also just done some general maintenance to the car, oil change, air filter, etc. I reset the codes and all was well...for a day! This morning, the light came back on, not yet sure of the code, but assuming it's the same.
I had a diagnostic done at chrysler prior to performing the aforementioned maintenance. They were going to replace the manifold pressure sensor, change valve covers, redo the entire ignition system, etc...($2300.00) haha...they were saying all kids of crap needed replaced, so I figured I would do most of it myself, which I did. So back to the question.
What the heck will fix this code? Replace the sensor? Keep looking for vac leak? Please help!!!
On a side note, it does have a little blue smoke here and there, like a valve seal leak, possibly rings, but it has 125000 on it. Let me know any suggestions!
Old 03-24-2008 | 05:53 PM
Default RE: P1400 Mnifold Pressure sensor!!!
start out with the sensor first what cant not be said is if the wires are good to and from the PCM.
alaskanJK
02-06-2021 10:00 AM
chicago11
01-03-2011 07:28 PM
SColeman
11-24-2008 07:40 PM
doug45601
13
11-15-2008 05:05 PM
vettman
08-15-2006 12:20 PM
