P1593 error code
P1593 error code
Hi, I just bought a 2007 Sebring Touring edition V6 3.5L. The problem is that cruise control is not working, a friend scanned and found the P1593 error stored in the car's computer. He reset the code but the function still not working. When I start the car the CRUISE light is not displayed. Can someone help me in diagnosing this situation, please?
Set Condition:
The PCM detects that the (V71) S/C Signal 1 voltage does not match the (V72) S/C Signal 2 voltage.
Possible Causes
INTERMITTENT DTC
(V71) S/C SIGNAL 1 CIRCUIT SHORTED TO VOLTAGE
(V72) S/C SIGNAL 2 CIRCUIT SHORTED TO VOLTAGE
(V71) S/C SIGNAL 1 CIRCUIT SHORTED TO GROUND
(V72) S/C SIGNAL 2 CIRCUIT SHORTED TO GROUND
(V71) S/C SIGNAL 1 CIRCUIT SHORTED TO THE (V937) S/C SWITCH GROUND CIRCUIT
(V72) S/C SIGNAL 2 CIRCUIT SHORTED TO THE (V937) S/C SWITCH GROUND CIRCUIT
(V71) S/C SIGNAL 1 CIRCUIT OPEN OR HIGH RESISTANCE
(V72) S/C SIGNAL 2 CIRCUIT OPEN OR HIGH RESISTANCE
(V937) S/C SWITCH GROUND CIRCUIT OPEN OR HIGH RESISTANCE
CLOCKSPRING
SPEED CONTROL SWITCH
STEERING CONTROL MODULE (SCM)
POWERTRAIN CONTROL MODULE (PCM)
First off, "CLEARING" a dtc when a fault still exists accomplishes ......NOTHING......
the speed control switches are separated into 2 sections, and PCM reads voltage changes between the two sections to determine a course of action. 1593 simply means that the voltage the PCM interprets from switch 1 IS IMPOSSIBLE, based on the reading from switch 2. ALL of the above are possible causes, But checking individual switch signals is impossible without specialized scan equipment....
Possible Causes
INTERMITTENT DTC
CLOCKSPRING
karayj
03-09-2013 02:51 PM
