pollen filter
Look in your owners manual. If you don't have one, go to chrysler.com and download it for free. There you will find this:
The A/C Air Filter is located in the fresh air inlet behind
the glove box. Perform the following procedure to replace
the filter:
1. Open the glove box and remove all contents.
2. Push in on the sides of the glove box and lower the
door.
3. Disconnect the glove box door dampener from the slot
on the side of the box. This is done by grasping the
dampener connector (on the outside of the box) and the
end of the connector pin (on the inside of the box) with
your thumb and forefinger and pulling outward while
lightly lifting upward on the door with your other hand.
Once disconnected, the dampener will retract underneath
the instrument panel if you release it.
4. Pivot the glove box downward.
5. Disengage the two retaining tabs that secure the filter
cover to the HVAC housing and remove the cover.
6. Remove the A/C Air Filter by pulling it straight out of
the housing.
7. Install the A/C Air Filter with the arrow on the filter
pointing toward the floor. When installing the filter
cover, make sure the retaining tabs fully engage the
cover.
You will also find a helpful illustration.
the filter:
door.
the housing.
cover.
Carlo60
04-07-2011 04:45 PM
bentleybloke
02-27-2008 02:34 PM
