Preffered Spark Plugs?
Old 10-14-2009 | 08:44 AM
ShawnyB's Avatar
Default Preffered Spark Plugs?
Any brand or type that are most efficient or does it really not matter?
I currently have a set of NGK V-power plugs on order.
Couldn't find a listing for spark plug wires so I assume the engine is a
coil-on-plug set up....this true?
Old 10-14-2009 | 11:14 AM
Yes, the 2002 2.7 is a coil-on-plug system.
I would go with platinum plugs. BTW, they come pre-gapped. The platinum plating is thin and can be destroyed by attempting to gap them the old-fashioned way, so don't.
To change the rear plugs, you'll need a couple of short (2") extensions with a u-joint between them. That will allow you to "roll" the socket down into the spark plug hole.
Be sure to use anti-sieze on the threads, and start the plugs in the threads using a piece of tubing to make sure you don't cross thread them.
Old 10-14-2009 | 01:02 PM
ShawnyB's Avatar
Now that's the kind of experienced feedback I am looking for
Thank You! Now I know what to expect when I am under the hood.
Old 10-14-2009 | 03:26 PM
champion plugs
WillQRose
10-18-2018 08:18 PM
austin
Cirrus & Breeze
09-16-2012 10:09 PM
Mykonoskid
04-21-2007 11:42 AM
boss dog
02-09-2006 02:13 PM
300Cno1
09-04-2005 06:06 PM
