Rear Stabilizer Bar end links, 02 convertible
Can anyone adivse as to how tight these should be? The book says 26 ft. lbs. but the only way I can get that reading with a torque wrench is if the nut is bottomed out on the bolt threads. Up until then the bushings just keep compressing. It seems they are way too compressed if I tighten them that far.
Torque wrench is good. It just seemed that the bushings were far more compressed than they should be. The nut turned fairly easily until I reached the end of the threads and then I made sure they were torqued to specs. If that is correct then I am good. Thanks.
nickstoyz
16
02-07-2015 02:15 PM
webbch
12-13-2006 12:11 PM
