Rubbing Sounds
Old 03-29-2009 | 12:47 AM
Bmad185's Avatar
Default Rubbing Sounds
I HAVE A 2006 CHRYSLER SEBRING SEDAN 4DOOR AND LAST YEAR I BOUGHT 20IN RIMS FOR MY CAR BUT I HEAR RUBBIN SOUNDS IT SOUNDS LIKE THE TIRE IS RUBBING ON SOMETHING BUT WHEN I LOOK AT MY TIRE IT IS FINE THERE IS NO RUBB MARKS OR NOTHING AT ALL ON IT I REALLY HEAR THE RUBBIN SOUND WHEN I HIT THE BRAKES I JUST RECENTLY BOUGHT BRAND NEW BREAKS SO THATS NOT THE PROBLUM SOME ONE PLEASE HELP
EMAIL- Bmad185@yahoo.com if any questions help
Old 03-29-2009 | 01:56 PM
Have you pulled the wheels off to inspect the back sides of the tires? Also check the wheel wells very carefully with a good light to look for signs of rubbing. If the new tire/wheel combination has a larger rolling radius, or a wider profile or a different offset, the chances of interference with the wheel well are pretty good because there isn't much room to spare.
If you can positively rule out any tire-to-wheel-well interference, then the next likely candidate is a bad wheel bearing. You might try spinning the wheels when they are off the ground. That may produce the noise, but may not without a load.
Could also be a dragging parking brake.
shaunneff
07-07-2011 11:56 PM
roadbandit
03-31-2010 06:26 PM
deadfish9
06-10-2009 07:57 PM
gaz440
02-21-2007 03:37 PM
drake
04-13-2006 12:07 AM
